[GRASS-dev] r.hazard.flood is not running in windows7( Grass 6.5)
Helmut Kudrnovsky hellik at web.de
Mon Jul 21 02:58:08 PDT 2014
SWAPAN GHOSH wrote
> Dear all,
> I succesfully the module r.hazards.flood.py in windows xp but fail in
> windows 7.
> Please help me.
> Regards,
> Swapan Ghosh
> grass-dev mailing list
> grass-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-dev
please provide more information how and what fails?
did you set the region right, e.g.
g.region -p -a rast=elevation at PERMANENT align=elevation at PERMANENT
tested here with
System Info
GRASS Version: 6.4.5svn
GRASS SVN Revision: 61153
GDAL/OGR: 1.11.0
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
(Mon Jul 21 11:47:06 2014)
r.hazard.flood --verbose map=elevation at PERMANENT flood=FLOOD mti=MTI
Done.
(Mon Jul 21 11:47:25 2014) Befehl ausgeführt (18 Sek)
System Info
GRASS Version: 7.0.0svn
GRASS SVN Revision: 61281
Erstellungsdatum: 2014-07-21
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
(Mon Jul 21 11:51:42 2014)
Done.
(Mon Jul 21 11:51:57 2014) Befehl ausgeführt (15 Sek)
r.hazard.flood in winGRASS6.4.5svn and winGRASS7.0.0svn works.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152074.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
