[GRASS-dev] r.hazard.flood is not running in windows7( Grass 6.5)
Swapan Ghosh
swap.ghsh at gmail.com
Mon Jul 21 03:17:57 PDT 2014
Actually, it needs external python installation.
I solve it...........
but my question is that.........why we need external py install.....other
wise get the following message
[image: Inline image 1]
Regards,
Swapan Ghosh
On Mon, Jul 21, 2014 at 3:28 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> SWAPAN GHOSH wrote
> > Dear all,
> > I succesfully the module r.hazards.flood.py in windows xp but fail in
> > windows 7.
> > Please help me.
> > Regards,
> > Swapan Ghosh
> > grass-dev mailing list
> > grass-dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> please provide more information how and what fails?
> did you set the region right, e.g.
> g.region -p -a rast=elevation at PERMANENT align=elevation at PERMANENT
> tested here with
> System Info
> GRASS Version: 6.4.5svn
> GRASS SVN Revision: 61153
> GDAL/OGR: 1.11.0
> PROJ4: Rel. 4.8.0, 6 March 2012
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
> (Mon Jul 21 11:47:06 2014)
> r.hazard.flood --verbose map=elevation at PERMANENT flood=FLOOD mti=MTI
> Done.
> (Mon Jul 21 11:47:25 2014) Befehl ausgeführt (18 Sek)
> System Info
> GRASS Version: 7.0.0svn
> GRASS SVN Revision: 61281
> Erstellungsdatum: 2014-07-21
> Build Platform: i686-pc-mingw32
> GDAL/OGR: 1.11.0
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> (Mon Jul 21 11:51:42 2014)
> Done.
> (Mon Jul 21 11:51:57 2014) Befehl ausgeführt (15 Sek)
> r.hazard.flood in winGRASS6.4.5svn and winGRASS7.0.0svn works.
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152074.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140721/8df0da15/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140721/8df0da15/attachment-0001.png>
