[GRASS-dev] r.hazard.flood is not running in windows7( Grass 6.5)
Swapan Ghosh
swap.ghsh at gmail.com
Mon Jul 21 06:13:26 PDT 2014
Dear all,
Thank you very much for the help.
Swapan
On Mon, Jul 21, 2014 at 4:29 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> >Actually, it needs external python installation.
> >I solve it...........
> >but my question is that.........why we need external py install.....other
> wise get the following message
> first, please don't use winGRASS 6.5, it's some kind of abandoned and not
> meant for productive use.
> so try winGRASS 6.4.5svn (latest stable in the 6.4-series) or winGRASS
> 7.0.0svn (first stable in the 7.0-series) first before installing an
> external python.
> an external python isn't normally necessary, but sometimes there are some
> glitches with windows and python.
> AFAICT the best thing is to use winGRASS within the OSGe4W-framework
> (http://trac.osgeo.org/osgeo4w/).
> for example the tests mentioned before by me are done in the
> OSGe4W-framework without any external python installation.
> in summary this isn't a r.hazard.flood issue, but a windows-python quirk
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/r-hazard-flood-is-not-running-in-windows7-Grass-6-5-tp5152002p5152094.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140721/da6e24c3/attachment.html>
