[GRASS-dev] [GRASS-SVN] r61282 - in grass/trunk: include/defs lib/raster3d lib/raster3d/test
Vaclav Petras wenzeslaus at gmail.com
Mon Jul 21 06:50:57 PDT 2014
On Sun, Jul 20, 2014 at 9:56 AM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> 2014-07-20 6:06 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > On Sat, Jul 19, 2014 at 8:02 PM, <svn_grass at osgeo.org> wrote:
> >> Unfortunately changed the editor that i use the indention and converted
> >> all tabs into spaces at save time. Hence,
> >> the commit contains 95% tab to space conversion noise.
> > I would actually agree with the change. I think that the GRASS
> indentation
> > style is a bug since mixed tabs and spaces are enforced as a rule (not
> just
> > allowed). However, it was decided that it won't be fixed and that current
> > practice should be preserved. [1]
> Mixing tabs and spaces is really a mess. And i am part of the problem,
> since i am using several different computer for development and
> different editors, each with its own habits.
> > Fortunately, there is a script which can enforce the unusual indent style
> > [2]. And also `svn diff --ignore-space-change` for cases like this
> commit.
> Thank you for this hint, i will try to use it.
See also improved:
http://trac.osgeo.org/grass/wiki/Submitting/C#Indentation
And just as a reminder for others, for Python code, use pep8 directly for
new code. For existing code use:
http://trac.osgeo.org/grass/wiki/Submitting/Python#Style
  pep8 --config=tools/pep8config.txt directory_to_check
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140721/4b96ba09/attachment.html>
