[GRASS-dev] [GRASS-SVN] r61282 - in grass/trunk: include/defs lib/raster3d lib/raster3d/test
Sören Gebbert
soerengebbert at googlemail.com
Sun Jul 20 06:56:24 PDT 2014
Hi Vaclav,
2014-07-20 6:06 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> On Sat, Jul 19, 2014 at 8:02 PM, <svn_grass at osgeo.org> wrote:
>> Unfortunately changed the editor that i use the indention and converted
>> all tabs into spaces at save time. Hence,
>> the commit contains 95% tab to space conversion noise.
> I would actually agree with the change. I think that the GRASS indentation
> style is a bug since mixed tabs and spaces are enforced as a rule (not just
> allowed). However, it was decided that it won't be fixed and that current
> practice should be preserved. [1]
Mixing tabs and spaces is really a mess. And i am part of the problem,
since i am using several different computer for development and
different editors, each with its own habits.
> Fortunately, there is a script which can enforce the unusual indent style
> [2]. And also `svn diff --ignore-space-change` for cases like this commit.
Thank you for this hint, i will try to use it.
> Anyway, I'm glad you discovered and fixed the bug. It is now painful for me
> to see that tests did not showed the bug. That's maybe why in an ideal
> world, tests are written by different person than the code (and without
> access/looking to the source code).
Yes, in an ideal world .... . Always expect bugs in the tests like you
would expect bugs in the actual code. :)
Best regards
Soeren
> Vaclav
> [1] http://trac.osgeo.org/grass/ticket/1663
> [2] http://trac.osgeo.org/grass/browser/grass/trunk/tools/grass_indent.sh
