[GRASS-dev] [GRASS-SVN] r60703 - in grass/trunk: display/d.vect general/g.gisenv gui/wxpython/animation lib/python/temporal raster/r.colors raster/r.external raster/r.in.bin raster/r.mapcalc raster/r.neighbors raster/r.out.bin raster/r.quant raster/r.resamp.filter raster/r.series raster/r.series.accumulate raster/r.series.interp raster/r.stats.quantile vector/v.colors vector/v.external.out
Huidae Cho grass4u at gmail.com
Tue Jul 22 11:58:03 PDT 2014
Well, there are no equivalent functions in python yet. Other than that, I
think this new API is functionally satisfying and r.clump is using it. The
patch looks good to me. BTW, I prefer option= and -f.
Regards,
Huidae
On Tue, Jul 22, 2014 at 1:53 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, Jun 25, 2014 at 2:09 AM, Huidae Cho <grass4u at gmail.com> wrote:
>> We also need to add option_rules or something to g.parser so that python
>> scripts can have access to these functions. Something like:
>> #%option_rules
>> #% exclusive: -a, -b
>> #% requires_all: opt1, opt2, -a
>> #%end
>> On Fri, Jun 20, 2014 at 9:59 PM, Huidae Cho <grass4u at gmail.com> wrote:
>>> G_option_excludes() works for me.
>>> On Fri, Jun 20, 2014 at 7:58 PM, Glynn Clements <
>>> glynn at gclements.plus.com> wrote:
>>>> Huidae Cho wrote:
>>>> > I assume G__check_option_rules() is supposed to be called by
>>>> G_parser().
>>>> > Then, instead of calling G_fatal_error, it should append errors to
>>>> > st->errors.
>>>> Okay; I presume that the intent is so that it will report all errors,
>>>> not just the first.
>>>> > If so... for g.mlist we can define two different versions of
>>>> > rules:
>>>> > This version prints more correct errors because only present
>>>> options/flags
>>>> > will be displayed in errors, but too much typing.
>>>> >     G_option_exclusive(flag.regex, flag.extended, NULL);
>>>> >     G_option_exclusive(flag.pretty, flag.full, NULL);
>>>> >     G_option_exclusive(flag.pretty, opt.output, NULL);
>>>> >     G_option_exclusive(flag.pretty, flag.mapset, NULL);
>>>> >     G_option_exclusive(flag.pretty, flag.type, NULL);
>>>> >     G_option_exclusive(flag.full, opt.output, NULL);
>>>> >     G_option_exclusive(flag.full, flag.mapset, NULL);
>>>> >     G_option_exclusive(flag.full, flag.type, NULL);
>>>> > This version is shorter, but -p -f will print three errors including
>>>> > options/flags not present.
>>>> >     G_option_exclusive(flag.pretty, flag.full, opt.output, NULL);
>>>> >     G_option_exclusive(flag.pretty, flag.full, flag.mapset, NULL);
>>>> >     G_option_exclusive(flag.pretty, flag.full, flag.type, NULL);
>>>> > Can we implement something like
>>>> > G_option_exclusive(pretty, full, G_option_or(output, mapset, type))
>>>> I'd rather stick to "flat" rules rather than heading in the direction
>>>> of generalised boolean expressions.
>>>> Not because it's hard to implement, but because it makes it harder to
>>>> utilise the information.
>>>> The next logical step is to include the rules in the
>>>> --interface-description output so that the GUI can convey the
>>>> relationships to the user. E.g. mutually-exclusive options might use
>>>> radio buttons, or greying-out excluded options. Options which are
>>>> required by another option could be marked as "required" when a value
>>>> is given for the first option. And so on.
>>>> Realistically, that requires that the rules belong to a finite set of
>>>> patterns.
>>>> > pretty, full, and any of output, mapset, and type are mutually
>>>> exclusive,
>>>> > but output, mapset, and type are not exclusive.
>>>> How about another rule type:
>>>> >     G_option_excludes(flag.pretty, opt.output, flag.mapset,
>>>> flag.type, NULL);
>>>> >     G_option_excludes(flag.full,   opt.output, flag.mapset,
>>>> flag.type, NULL);
>>>> where the first option excludes all remaining options.
>>>> This is essentially the negation of G_option_requires().
>>>> Glynn Clements <glynn at gclements.plus.com>
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Hi,
> is this new API now stable enough to be actually used in C modules? Should
> we start to replace the manual checks in modules with these functions? BTW,
> documentation is still missing.
>  I attached a patch which should fix this ticket [1]: when user doesn't
> type any command arguments and the module has no explicitly required
> options (like g.region), it checks if there is any RULE_REQUIRED and if
> yes, it opens GUI dialog.
> Also I would consider a little bit better error message, the name of the
> option is not very visible in the sentence. Perhaps using quotes or <>
> around the option would help. Also, "Option myoption1 requires at least one
> of myoption2" sounds weird, perhaps there should be special handling of
> cases when there is just one option required. These are just details.
> Thanks,
> Anna
> [1]http://trac.osgeo.org/grass/ticket/1778
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140722/2c764802/attachment-0001.html>
