[GRASS-dev] [GRASS-SVN] r60703 - in grass/trunk: display/d.vect general/g.gisenv gui/wxpython/animation lib/python/temporal raster/r.colors raster/r.external raster/r.in.bin raster/r.mapcalc raster/r.neighbors raster/r.out.bin raster/r.quant raster/r.resamp.filter raster/r.series raster/r.series.accumulate raster/r.series.interp raster/r.stats.quantile vector/v.colors vector/v.external.out
Tue Jul 22 14:05:31 PDT 2014
Anna Petrášová wrote:
> is this new API now stable enough to be actually used in C modules? Should
> we start to replace the manual checks in modules with these functions?
I think so.
> I attached a patch which should fix this ticket [1]: when user doesn't type
> any command arguments and the module has no explicitly required options
> (like g.region), it checks if there is any RULE_REQUIRED and if yes, it
> opens GUI dialog.
Looks good.
