[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
trac at osgeo.org
Mon Jun 2 22:33:25 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: separator, pipe, r.out.xyz, r.stats | Platform: MSWindows 7
Cpu: All |
Comment(by glynn):
Replying to [comment:30 hcho]:
> Setting shell=False alone doesn't fix this problem. We still need
{{{^^^|}}} (4 less carets).
Why? The caret-escape mechanism is specific to cmd.exe, which is no longer
used. The escaping needed to ensure that the command's "argv" array has
the correct values is performed by the subprocess module (and doesn't
involve carets).
> Also, we lose useful cmd.exe commands (e.g., cd, dir, type, ...).
A Python script shouldn't be executing such commands, but should be using
Python's own functionality. In particular, executing a "cd" command in a
child process is pointless, as its effect is limited to the child process
itself.
In any case r60679 removes all of the Popen() hackery from
grass.script.core.py. grass.script.Popen() is now effectively an alias for
subprocess.Popen().
Execution of (e.g.) Python scripts from within Python scripts will require
either specifying the interpreter explicitly, or the use of a batch file,
or specifying shell=True (and providing any necessary quoting).
Ultimately, it's impossible to quote correctly when shell=True, as it uses
%COMSPEC% (if it's set) as the interpreter, and there's no guarantee that
it will use exactly the same quoting rules as cmd.exe.
Technically, similar issues apply when shell=False, as it's up to the
executable to parse the command line into arguments. Fortunately, the
parsing rules are now documented and widely followed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:31>
