[GRASS-dev] [GRASS GIS] #2321: Assign suitable map output typ automatically in modules which use lib/stats
GRASS GIS trac at osgeo.org
Mon Jun 2 23:40:27 PDT 2014
 Reporter:  sbl          |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  Raster       |     Version:  unspecified
 Keywords:               |    Platform:  All
      Cpu:  All          |
 Recently Glynn implemented a logic for assigning the moste suitable output
 type (integer / float) to maps produced in r.neighbors.
 Basically, all modules which use lib/stats would benefit from such a
 logic, like r.resamp.stats, r.series, r.series.interp, r3.neighbors,
 v.vect.stats and possibly r.in.xyz, as well all modules which are based on
 them (e.g. t.rast.aggregate).
 Implementing Glynns logic on library level would help to both avoid that
 maps produced with these modules unnecessarily occupy hard disk space and
 speed up subsequent operations as well as it would spare users who care
 about the storage type from running r.mapcalc int() / float() and g.remove
 after one of the named commands.
 Not sure how FCELL/DCELL differences for float output could/should be
 tackled...
 For the original discussion see:
 http://osgeo-org.1560.x6.nabble.com/G7-r-neighbors-changes-data-type-from-
 CELL-to-DCELL-tt5134367.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2321>
