[GRASS-dev] G7: r.neighbors changes data type from CELL to DCELL
Mon Jun 2 22:44:58 PDT 2014
Blumentrath, Stefan wrote:
> > In theory, the same logic could be used for anything which uses
> > lib/stats, i.e. r.neighbors, r.resamp.stats, r.series,
> > r.series.interp, r3.neighbors, and v.vect.stats.
> Thanks for your reply, and sorry that mine took a while.
> Provided that I neither have an idea how much work it would be to
> implement that in a more general approach, nor the competence to do
> so, would you mind if I open an enhancement request in trac?
That's probably the best course of action.
