[GRASS-dev] [GRASS GIS] #2320: PyGRASS doesn't write 3D vector map
GRASS GIS trac at osgeo.org
Mon Jun 2 14:03:53 PDT 2014
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Python       |     Version:  svn-trunk
 Keywords:  pygrass      |    Platform:  All
      Cpu:  Unspecified  |
 When I create a new vector using PyGRASS, create 3D points and write them
 to the map, v.info says the map is 2D. The problem is that PyGRASS doesn't
 specify anywhere that the map should be 3D. The following change works for
 me but I am not completely sure it's correct:
 Index: pygrass/vector/__init__.py
 --- pygrass/vector/__init__.py  (revision 60631)
 +++ pygrass/vector/__init__.py  (working copy)
 @@ -187,6 +187,12 @@
          if geo_obj.gtype == _Area.gtype:
              result = self._write_area(geo_obj)
 +        if not geo_obj.is2D:
 +            self.c_mapinfo.contents.head.with_z = 1
 +            self.c_mapinfo.contents.plus.with_z = 1
 +            self.c_mapinfo.contents.plus.spidx_with_z = 1
          result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
                                           geo_obj.c_points,
 geo_obj.c_cats)
          if result == -1:
Ticket URL: <http://trac.osgeo.org/grass/ticket/2320>
