[GRASS-dev] [GRASS GIS] #2320: PyGRASS doesn't write 3D vector map
trac at osgeo.org
Mon Jun 2 23:43:17 PDT 2014
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Keywords: pygrass | Platform: All
Cpu: Unspecified |
Comment(by zarch):
Thanks to look into it!
I have 2 doubts:
* I'm not sure if it is correct to silently switch the vector map from 2D
to 3D when the user try to write a geometry feature. Maybe we should move
the patch from the write method to open (in abstract/Info), in this way we
don't have to check if the geo_obj.is2D for each call to the writing
method and user have to open the vector map explicity with 3D enabled. So
user could write something like:
with VectorTopo("new3D", mode="w", is2D=False) as vect:
vect.write(Point(10, 20, 100))
Actually I don't like too much the is2D parameter in the open method,
perhaps is3D could be clearer, but we should change the attribute of the
geometry features from is2D to is3D for consistency.
* Do you know if there is a function in the GRASS API to enable 3D on
vector map instead of directly modifying the c_mapinfo structure? If not
your approach it looks fine to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2320#comment:1>
