[GRASS-dev] g.mlist list multiple types from all mapsets
Vaclav Petras
wenzeslaus at gmail.com
Tue Jun 3 06:15:30 PDT 2014
On Tue, Jun 3, 2014 at 4:08 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2014-06-03 10:04 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
> > you mean the new g.mremove with the g.mlist interface
> > (http://trac.osgeo.org/grass/attachment/ticket/2228/g-mremove-main.diff
> I had in mind replacing g.remove with g.mremove, but right,
> consolidating interfaces would be also nice...
> Agreed. Note also that there are is good reasoning behind the new
interface by Glynn and Huidae [1] besides the fact the old g.mremove was
used for a long time. Also I've tried to test the new interface [2].
Vaclav
[1] http://trac.osgeo.org/grass/ticket/2228#comment:6
[2] http://trac.osgeo.org/grass/attachment/ticket/2228/test_g_mremove.py
PS: Now I see that the test contains a bug, the first method is not
executed because I gave the same name to the second one. I should use
pylint next time.
Martin
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140603/a25a4cac/attachment-0001.html>
