[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho grass4u at gmail.com
Tue Jun 3 07:10:24 PDT 2014
Vaclav,
Your test script is working great. I think it's ok to overwrite the first
method because the second one actually tests the new g.mremove anyway. I
deleted the first method and it worked fine.
Huidae
On Tue, Jun 3, 2014 at 9:15 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Jun 3, 2014 at 4:08 AM, Martin Landa <landa.martin at gmail.com>
> wrote:
>> 2014-06-03 10:04 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
>> > you mean the new g.mremove with the g.mlist interface
>> > (http://trac.osgeo.org/grass/attachment/ticket/2228/g-mremove-main.diff
>> I had in mind replacing g.remove with g.mremove, but right,
>> consolidating interfaces would be also nice...
>> Agreed. Note also that there are is good reasoning behind the new
> interface by Glynn and Huidae [1] besides the fact the old g.mremove was
> used for a long time. Also I've tried to test the new interface [2].
> Vaclav
> [1] http://trac.osgeo.org/grass/ticket/2228#comment:6
> [2] http://trac.osgeo.org/grass/attachment/ticket/2228/test_g_mremove.py
> PS: Now I see that the test contains a bug, the first method is not
> executed because I gave the same name to the second one. I should use
> pylint next time.
>  Martin
>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140603/2367a383/attachment.html>
