[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Moritz Lennert
mlennert at club.worldonline.be
Thu Jun 5 08:36:47 PDT 2014
On 04/06/14 22:35, Markus Neteler wrote:
> On Wed, Jun 4, 2014 at 7:56 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
>> So either:
>> 1. GRASS 7 will need .bat wrappers for Python scripts on Windows. That
>> has the same issues as using shell=True, but at least it only applies
>> in the case where we're executing a script.
> ... this would follow the apparently working method in GRASS 6.
> Maybe worth a try also in GRASS 7 at this point.
I had the feeling that this was the "consensus" (or at least with lack
of clear dissension) we had reached:
http://lists.osgeo.org/pipermail/grass-dev/2014-April/068519.html
Moritz
