[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Moritz Lennert mlennert at club.worldonline.be
Thu Jun 5 23:50:08 PDT 2014
On 05/06/14 21:14, Martin Landa wrote:
> Hi,
> 2014-06-05 17:36 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
>>> ... this would follow the apparently working method in GRASS 6.
>>> Maybe worth a try also in GRASS 7 at this point.
>> I had the feeling that this was the "consensus" (or at least with lack of
>> clear dissension) we had reached:
> "consensus" is somehow courageous to say, bearing in mind that Glynn
> simply reverts any other solution regardless that it breaks the whole
> GRASS on Windows (try to install 7.1, completely useless, even no
> answer, break is just OK). Well, someone need to implement it, even
> some of us are not probably happy about that, we need to take care
> about user scripts and so on. It's somehow funny, because 7.0 simply
> works (same was for 7.1 some days ago).
Have you looked at the reason for Glynn's revert ? Do you have a better
suggestion to solve the problem at hand ?
Moritz
