[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho
grass4u at gmail.com
Sun Jun 8 07:57:02 PDT 2014
G.mlist seems to be tested enough (?), but is someone testing the new
g.mremove (g.mlist interface)? It worked for me at least...
I think it's safe to replace g.list with g.mlist at this point, but I have
a good history of getting reverted ;-). No more votes and 0 vetoes. Good or
bad sign?
On Jun 6, 2014 12:18 PM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On Tue, Jun 3, 2014 at 3:43 AM, Huidae Cho <grass4u at gmail.com> wrote:
>> I tested g.mlist with the attached script. I started from test_g_list.py
>> and replaced g.list with g.mlist -p and g.list -f with g.mlist -f. g.
>> mlist passed the test, which means g.list == g.mlist -p & g.list -f == g.
>> mlist -f.
> More tests needed. g.mlist does not complain about not existing mapset:
> $ g.mlist pattern="lsat*" type=rast mapset=xxxxxx
> [no output]
> $ echo $?
> 0
> By the way, is multiple for mapset a planned feature? Or it is too much?
> Pattern for mapset seems too much for sure.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140608/6d9b0979/attachment.html>
