[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho grass4u at gmail.com
Thu Jun 19 10:30:35 PDT 2014
FYI, multiple mapsets implemented in r60872.
On Sun, Jun 8, 2014 at 8:30 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Sun, Jun 8, 2014 at 7:10 AM, Huidae Cho <grass4u at gmail.com> wrote:
>> Non-existent mapset fixed in r60749.
>> Thanks. I can confirm that it works. Now we need the test for it.
> On Fri, Jun 6, 2014 at 12:18 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> By the way, is multiple for mapset a planned feature? Or it is too much?
>> Pattern for mapset seems too much for sure.
>> Multiple mapsets is not too much, but do we need it?
> I don't know. I asked because I just automatically tried that syntax
> because I used `pattern="something,some_*"` syntax recently.
>> Also, if we implement multiple mapsets, it would be better semantically
>> to change "mapset=.." to "mapset=*" for all mapsets in the current
>> location. Martin, do you mind if I change mapset=.. to mapset=*?
>> I would say that in any case, * fits more with the other options,
> although * is also used also for null values (besides nv and others).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140619/acb19652/attachment-0001.html>
