[GRASS-dev] G__ in public API
Vaclav Petras wenzeslaus at gmail.com
Tue Jun 10 07:01:55 PDT 2014
On Tue, Jun 10, 2014 at 9:56 AM, Huidae Cho <grass4u at gmail.com> wrote:
> I agree. One of the main reasons why G__ routines are used is there is no
> alternative ways to achieve certain tasks. Then they should be exposed to
> module developers. If it's not the case, those routines have to replaced
> with correct G_ versions.
> For example, I recently used G__mapset_permissions in g.mlist.
This might be a part of advanced API, but it is still an API, it is not
internal.
 On Jun 10, 2014 9:33 AM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
>> On Tue, Jun 10, 2014 at 4:12 AM, Martin Landa <landa.martin at gmail.com>
>> wrote:
>>> Hi all,
>>> many of modules are using G__ functions which should be dedicated for
>>> internal use only (in libs level). Those which are used by modules I
>>> would suggest to rename to G_ (before GRASS 7 release).  Any
>>> objections, comments?
>>> I agree that something must be done. It took me a while before I
>> understood that double underscore methods are meant to be private (because
>> of lack of documentation and bad examples in modules' code).
>> Vaclav
>> Martin
>>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140610/12dc9380/attachment-0001.html>
