[GRASS-dev] [GRASS GIS] #2333: choose python interpreter during the GRASS installation on windows
GRASS GIS trac at osgeo.org
Thu Jun 12 02:11:12 PDT 2014
 Reporter:  zarch                                 |       Owner:  grass-dev@…
     Type:  enhancement                           |      Status:  new
 Priority:  normal                                |   Milestone:  7.1.0
Component:  Python                                |     Version:  svn-trunk
 Keywords:  windows installer python interpreter  |    Platform:  MSWindows 8
      Cpu:  All                                   |
 Using the Windows installer would be great to be able to choice which
 python interpreter must be used by GRASS.
 Suppose that we have already installed a python interpreter like
 [https://code.google.com/p/pythonxy/ pythonxy], at the moment the GRASS
 installer use is own python interpreter therefore if I want to use any
 python packages from GRASS, like [http://www.scipy.org/ scipy] or
 [http://pandas.pydata.org/ pandas] I have, some how, to install these
 packages on the GRASS interpreter even if they are already present in
 pythonxy.
 Do you think that would be possible to add this point to the GRASS
 installer? or It is not possible to add this option because GRASS must be
 compiled using the new interpreter? where should I look to try to add this
 option?
 Any hints?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2333>
