[GRASS-dev] [GRASS GIS] #2332: change r.horizon output names from "angle index" to "angle"
trac at osgeo.org
Wed Jun 18 03:05:13 PDT 2014
Reporter: zarch | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Keywords: r.horizon | Platform: All
Cpu: All |
Comment(by zarch):
Replying to [comment:5 wenzeslaus]:
> Replying to [comment:2 zarch]:
> > Replying to [comment:1 annakrat]:
> > > I don't like the dot there, though, since it's not valid for
> > > vector maps and that's a source of confusion then.
> > I don't like either, but I don't see any better solution, do you?
> The only possibility I see is to replace this dot with an
> underscore, too: h_06_5, h_07_0, h_07_5. But the names are
> not so nice anymore but wouldn't use colon for hour neither
> (h_06:30 vs h_06_30), so maybe the underscore is actually
> quite good.
Actually I don't like too much the idea of replace dot with underscore, we
loose readability. To improve readability perhaps we can use two
underscore as separator between basename and numbers, like:
basename__006_5
The other disadvantage is that instead of using the standard C format
string like: "basename_%05.2f" to generate the name, we have to define a
function to split the integer and the decimal part, and we have to take
care if the number of decimals is 0, then we have to switch the format,
something like:
void get_name(const char *basename, double number, size_t decimals, char
*name)
double integer, decimal;
integer = floor(number);
if (decimals != 0){
decimal = ((number - integer) * pow(10., (double)decimals));
sprintf(name, "%s__%03d_%d", basename, (int)integer,
(int)decimal);
else{
sprintf(name, "%s__%03d", basename, (int)integer);
and then:
get_name("basename", 12.34567890, 2, name); // => basename__012_34
get_name("basename", 12.34567890, 0, name); // => basename__012
If we choose this option, this function should be put somewhere in GRASS
library because other modules like r.sun must be able to reproduce the
same logic, moreover have a function that generate the name given the
basename and number should make easier to maintain consistency over the
grass modules.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2332#comment:6>
