[GRASS-dev] [GRASS GIS] #2333: choose python interpreter during the GRASS installation on windows
trac at osgeo.org
Thu Jun 19 05:40:56 PDT 2014
Reporter: zarch | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: windows installer python interpreter | Platform: MSWindows 8
Cpu: All |
Comment(by glynn):
Replying to [comment:20 martinl]:
> > So, do we mimic the shell (locate the program and determine its
suffix), or use it (and
> There was something similar installed for Python scripts (1).
Right. But if we take that route, it should apply to everything. And if
the extension isn't one which !CreateProcess() handles directly (exe, bat,
cmd, what else?), we should set shell=True (and ideally perform any
necessary escaping).
IOW, something like:
class Popen(subprocess.Popen):
def __init__(self, args, ...):
if sys.platform == 'win32' and isinstance(args, list):
cmd = shutil_which(args[0])
args = [cmd] + args[1:]
name, ext = os.path.splitext(cmd)
if ext.lower() not in ['.exe', '.bat', '.cmd']:
shell = True
args = [escape_for_shell(arg) for arg in args]
subprocess.Popen.__init__(self, args, shell=shell, ...)
> > I still don't consider the previous approach (use the shell, don't
bother escaping anything) to be a viable solution.
> Using `shell=True` seems to be less problematic to me, is it problem to
determine escaping rules for special characters (I know only about pipe
problem till now).
I'm unsure what the rules are, whether they're sufficient (i.e. whether
there are sequences which simply cannot be passed), or whether I'd trust
any documentation to be accurate. I also don't know whether there are any
other gotchas (ANSI-versus-OEM codepage issues?). But we don't really have
a choice; execution of arbitrary scripts has to go through the shell one
way or another. The main thing is that we don't get the shell involved
unless we have to (i.e. we don't do it for EXEs).
The specific issue with the parser() function can be dealt with by using
'g.parser.exe' on Windows. And it should probably use subprocess.Popen()
directly rather than grass.script.Popen(), to avoid any issues with
whatever magic may be added to the latter. Executing g.parser with
shell=True may be where the need for double-escaping was coming from.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2333#comment:22>
