[GRASS-dev] grass71 and GDAL read
Huidae Cho
grass4u at gmail.com
Tue Jun 24 14:06:49 PDT 2014
Jachym,
I recently tried the same thing (gdal-2014-04-24 and GRASS 7 trunk). You
can find my patches at http://trac.osgeo.org/gdal/ticket/2953, which work
for me. I didn't try the plugin way though.
Huidae
On Tue, Jun 24, 2014 at 4:27 PM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2014-06-24 22:09 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> > I wanted to publish some maps via MapServer, using GDAL, like the old
> > days. But I did not succeed to get it compiled with GRASS (at first
> > try). What is the best way you would propose to approach?
> > 1 - compile gdal withnout grass
> > 2 - compile grass 7.1 with gdal support
> > 3 - compile gdal again with grass support?
> > It worked some years back, but does it still apply?
> best is to compile GRASS driver as a plugin, anyway GRASS 7 support in
> GDAL is still open issue [1].
> Martin
> [1] http://trac.osgeo.org/gdal/ticket/2953
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140624/10360bde/attachment.html>
