[GRASS-dev] grass71 and GDAL read
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Jun 27 00:11:42 PDT 2014
Hi Martin,
ok, sorry, but I'm a bit confused from amount of patches, which are
attached to the ticket and none of them seems to be working on
gdal-grass-1.4.3.
I'm using GRASS 7.1 btw, so I hope, that is ok in general.
Could you point me please to patches, which should work with
http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz ?
Thanks
2014-06-24 22:27 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2014-06-24 22:09 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>> I wanted to publish some maps via MapServer, using GDAL, like the old
>> days. But I did not succeed to get it compiled with GRASS (at first
>> try). What is the best way you would propose to approach?
>> 1 - compile gdal withnout grass
>> 2 - compile grass 7.1 with gdal support
>> 3 - compile gdal again with grass support?
>> It worked some years back, but does it still apply?
> best is to compile GRASS driver as a plugin, anyway GRASS 7 support in
> GDAL is still open issue [1].
> Martin
> [1] http://trac.osgeo.org/gdal/ticket/2953
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
