[GRASS-dev] grass71 and GDAL read
Huidae Cho
grass4u at gmail.com
Fri Jun 27 03:13:42 PDT 2014
Try the attached patches. The GRASS plugin works for me.
./configure --with-autoload=/usr/lib/gdalplugins
--with-grass=/your/grass/path
Huidae
On Fri, Jun 27, 2014 at 3:11 AM, Jachym Cepicky <jachym.cepicky at gmail.com>
wrote:
> Hi Martin,
> ok, sorry, but I'm a bit confused from amount of patches, which are
> attached to the ticket and none of them seems to be working on
> gdal-grass-1.4.3.
> I'm using GRASS 7.1 btw, so I hope, that is ok in general.
> Could you point me please to patches, which should work with
> http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz ?
> Thanks
> 2014-06-24 22:27 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> > Hi,
> > 2014-06-24 22:09 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> >> I wanted to publish some maps via MapServer, using GDAL, like the old
> >> days. But I did not succeed to get it compiled with GRASS (at first
> >> try). What is the best way you would propose to approach?
> >> 1 - compile gdal withnout grass
> >> 2 - compile grass 7.1 with gdal support
> >> 3 - compile gdal again with grass support?
> >> It worked some years back, but does it still apply?
> > best is to compile GRASS driver as a plugin, anyway GRASS 7 support in
> > GDAL is still open issue [1].
> > Martin
> > [1] http://trac.osgeo.org/gdal/ticket/2953
> > Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140627/72fa4174/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140627/72fa4174/attachment.zip>
