[GRASS-dev] grass71 and GDAL read
Jachym Cepicky jachym.cepicky at gmail.com
Mon Jun 30 01:12:03 PDT 2014
Worked, but had to add -I/usr/include/postgresql/ to CPPFLAGS
seems to be compiled and in gdal
thank you
2014-06-27 12:13 GMT+02:00 Huidae Cho <grass4u at gmail.com>:
> Try the attached patches. The GRASS plugin works for me.
> ./configure --with-autoload=/usr/lib/gdalplugins
> --with-grass=/your/grass/path
> Huidae
> On Fri, Jun 27, 2014 at 3:11 AM, Jachym Cepicky <jachym.cepicky at gmail.com>
> wrote:
>> Hi Martin,
>> ok, sorry, but I'm a bit confused from amount of patches, which are
>> attached to the ticket and none of them seems to be working on
>> gdal-grass-1.4.3.
>> I'm using GRASS 7.1 btw, so I hope, that is ok in general.
>> Could you point me please to patches, which should work with
>> http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz ?
>> Thanks
>> 2014-06-24 22:27 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>> > Hi,
>> > 2014-06-24 22:09 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>> >> I wanted to publish some maps via MapServer, using GDAL, like the old
>> >> days. But I did not succeed to get it compiled with GRASS (at first
>> >> try). What is the best way you would propose to approach?
>> >> 1 - compile gdal withnout grass
>> >> 2 - compile grass 7.1 with gdal support
>> >> 3 - compile gdal again with grass support?
>> >> It worked some years back, but does it still apply?
>> > best is to compile GRASS driver as a plugin, anyway GRASS 7 support in
>> > GDAL is still open issue [1].
>> > Martin
>> > [1] http://trac.osgeo.org/gdal/ticket/2953
>> > Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>> Jachym Cepicky
>> e-mail: jachym.cepicky gmail com
>> URL: http://les-ejk.cz
>> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Jachym Cepicky
