[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Tue Jun 24 17:41:03 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script, exceptions | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
When trying to implement new version of what we are talking about I run
into the following problem. G7:g.message which is called by `core.fatal`
exits with non-zero return code.
# test runs of g.message
> g.message "no flag"; echo "$?"
no flag
0
> g.message -v "flag -v"; echo "$?"
0
> g.message -i "flag -i"; echo "$?"
flag -i
0
> g.message -w "flag -w"; echo "$?"
WARNING: flag -w
0
> g.message -e "flag -e"; echo "$?"
ERROR: flag -e
1
This causes `run_command` which is used to call `g.message` to call
`core.fatal` and infinite recursion goes on. `g.message` calls
`G_fatal_error` which in causes the exit with return code 1.
This can be fixed in `core.fatal` (`core.error`) for example by using
`start_command` directly. However, the behavior of `g.message` is not
expected. When it successfully prints the error, it should end
successfully. Wouldn't be better to change `g.message` to return 0 with
`-e` flag?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:10>
