[GRASS-dev] [GRASS GIS] #2326: Command functions in grass.script.core miss a correct error reporting
trac at osgeo.org
Tue Jun 24 20:34:58 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: script, exceptions | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
I've added new patch. Functions call one of the following error handing
functions:
#!python
def _called_command_error(returncode, args, kwargs):
msg = _("Command %s %s returned non-zero exit status %s") % (args,
kwargs, returncode)
if _RAISE_ON_COMMAND_ERROR:
raise CalledCommandError(msg, returncode, args, kwargs)
fatal(msg) # this exits or raises
def _called_command_return(returncode, args, kwargs):
if _RETURN_ON_COMMAND_ERROR:
return returncode
elif returncode:
Examples of functions:
#!python
# we can return return code, raise or exit
def run_command(*args, **kwargs):
ps = start_command(*args, **kwargs)
returncode = ps.wait()
return _called_command_return(returncode, args, kwargs)
#!python
# we want to always return output here, so raise or exit
def read_command(*args, **kwargs):
process = pipe_command(*args, **kwargs)
output = process.communicate()[0]
returncode = process.poll()
if returncode:
return output
* I don't call `wait()` or `poll()` in the checking method, this is done
in the functions in different (appropriate) ways.
* There is no interface yet for the global variables which controls if
the functions will raise, exit/fatal or return (if applicable).
* I'm using `message(msg, flag='w')` instead of `message(msg, flag='w')`
to avoid issue described in comment:10.
* Besides global variables there may or probably should be also a
parameter which will apply to individual functions. But I still have a
feeling that I would like to use special function, no a function with
parameter.
* Functions `read_command` and `write_read_command` capture stdout, so I
don't see a reason to not capture also stderr and print it (perhaps
begging and end) in the error message, except for inconsistency with other
functions. Again I still have a feeling that I want this also for other
functions.
* I was looking to [source:grass/trunk/gui/wxpython/core/gcmd.py#L553
gui/wxpython/core/gcmd.py] and I'm wondering why there is so much code
around `subprocess.Popen` call and why it is not needed in `script.core`.
* I'm still thinking how to include this changes into trunk and 7_0. It
is a change of API and it requires to go to almost 200 places in trunk and
addons (see comment:5).
Download the test, e.g. to `/lib/python/script/testsuite` directory, and
run it (inside GRASS session):
python -m unittest discover lib/python/script/testsuite
Ticket URL: <http://trac.osgeo.org/grass/ticket/2326#comment:11>
