[GRASS-dev] [GRASS GIS] #2229: error in projection definition
trac at osgeo.org
Wed Jun 25 01:56:41 PDT 2014
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Projections/Datums | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by hamish):
I suspect the fact that epsg 3857 is a new entry for the epsg file
(replaces 900973 from extra.esri) may have something to do with it. How
does it act for codes which do not exist?
Vincent, what version of proj4 and gdal are you using? what platform?
did you try to then specify the definition manually by +proj4 terms or by
manually choosing ellips to be sphere, etc?
Hamish
ps- please try to only use pseudo-mercator if data import/export demands
it, it is the cause of much pain. :-)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:2>
