[GRASS-dev] [GRASS GIS] #2229: error in projection definition
trac at osgeo.org
Wed Jun 25 02:46:26 PDT 2014
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Projections/Datums | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by vincent):
Replying to [comment:2 hamish]:
> Vincent, what version of proj4 and gdal are you using? what platform?
Quite old ones :
proj4 :
Rel. 4.7.1, 23 September 2009
gdal :
GDAL 1.9.0, released 2011/12/29
uname --all :
Linux pc1 3.2.0-4-amd64 Debian 3.2.57-3 x86_64 GNU/Linux
> did you try to then specify the definition manually by +proj4 terms or
by manually choosing ellips to be sphere, etc?
Yes, passing the proj4 chain gives the right projection, see this
[http://lists.osgeo.org/pipermail/grass-user/2014-March/070030.html
thread] for history.
> ps- please try to only use pseudo-mercator if data import/export demands
it, it is the cause of much pain. :-)
I keep it in mind from then...
V.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2229#comment:3>
