[GRASS-dev] C++ program - Accessing vector data and column tables
Martina M
duda1000 at hotmail.es
Wed Jun 25 08:24:30 PDT 2014
Hello,
I want to create a C++ program to access the vector data in Grass. I use Vect_open_old to open the table and Vect_read_line to access the geometrical data. However, I don't know how to access to the column data. Should I use GRASS DataBase Management Interface? Any example code?
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140625/cf6942e8/attachment.html>
