[GRASS-dev] C++ program - Accessing vector data and column tables
Anna Petrášová kratochanna at gmail.com
Wed Jun 25 08:39:09 PDT 2014
On Wed, Jun 25, 2014 at 11:24 AM, Martina M <duda1000 at hotmail.es> wrote:
> Hello,
>   I want to create a C++ program to access the vector data in Grass. I use
> Vect_open_old to open the table and Vect_read_line to access the
> geometrical data. However, I don't know how to access to the column data.
> Should I use GRASS DataBase Management Interface? Any example code?
> Thanks in advance
here is an example:
http://trac.osgeo.org/grass/browser/grass/trunk/doc/vector/v.example/main.c
Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140625/719d3c4c/attachment.html>
