[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
trac at osgeo.org
Wed Jun 25 08:53:59 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Parser | Version: svn-releasebranch64
Keywords: base name, prefix, basename | Platform: All
Cpu: All |
Comment(by annakrat):
Replying to [comment:9 zarch]:
> Replying to [comment:8 wenzeslaus]:
> > Replying to [comment:6 annakrat]:
> > > Replying to [comment:4 zarch]:
> > > > So maybe in the future the GUI would be able to group maps
> > > > following the rule "basename`__`*" and visualize them in
> > > > the wxGUI Animation or something else...
> > > I agree with double underscore.
> > I'm not sure about double underscore. I don't like how it
> > looks like. I'm afraid if it will be understandable for users,
> > for example when visualized in some GUI, you don't know how the
> > font will show it (with mono spaced font, you can see two
> > underscores even if they are connected with each other, with
> > other fonts, you don't know). Moreover, so systems can try
> > to interpret the double underscore too (see what Trac did to
> > commit message in r60944).
> > On the other hand, I see the advantages too. It is much harder
> > or more fragile to achieve the same with one underscore
> > (or other character).
> I see two options:
> - avoid to use any separator;
> - choose a "standard" separator for map names;
> I think that define a standard separator could open new possibilities to
GRASS GUI/interaction. So I believe we should choose one.
> Concerning which separator we should use, personally I've not strong
opinion about double underscore, my idea is that one underscore is quite
common in the raster/vector names so I don't think it is a good candidate
to be used as separator.
> Personally I like the use of a peculiar character like: », ■, or other
because user should never insert such characters manually and clearly mark
which maps are automatically generated my GRASS modules, and as far as I
know they have not particular meaning in other system like shell, trac,
etc..
Map names can't have this weird characters, check `G_legal_filename`. I
still think '`__`' is the best option.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:10>
