[GRASS-dev] [GRASS GIS] #2017: ogsf compilation error
GRASS GIS trac at osgeo.org
Wed Jun 25 09:08:01 PDT 2014
 Reporter:  martinl                        |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  critical                       |   Milestone:  7.0.0
Component:  Compiling                      |     Version:  svn-trunk
 Keywords:  libc, ogsf, libavutil, ffmpeg  |    Platform:  Linux
      Cpu:  x86-64                         |
Comment(by neteler):
 FWIW, I tested edleaver's suggestion on Ubuntu 14.04:
 Replying to [comment:13 edleaver]:
 > 1. remove /usr/include/libavutil/ from --with-ffmpeg-includes paths
 > 2. lib/ogsf/gsd_img_mpeg.c line 33 should read
 >       #include <libavutil/mathematics.h>
 >    rather than
 >       #include <mathematics.h>
 > That should be all that is necessary, for now.
 ... unfortunately no success:
 grass70_release/lib/ogsf$ make
 gcc  -g -O2  -fPIC  -I/home/alba/source_code/grass70_release/dist.x86_64
 -unknown-linux-gnu/include
 -I/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-
 gnu/include   -I/usr/include/gdal -I/usr/include
 -DPACKAGE=\""grasslibs"\"  -I/usr/include/postgresql
 -I/usr/include/libavcodec -I/usr/include/libavformat
 -I/usr/include/libswscale -I/usr/include/libavutil
 gnu/include -I/home/alba/source_code/grass70_release/dist.x86_64-unknown-
 linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c
 In file included from /usr/include/x86_64-linux-gnu/sys/stat.h:105:0,
                  from /home/alba/source_code/grass70_release/dist.x86_64
 -unknown-linux-gnu/include/grass/defs/gis.h:64,
 -unknown-linux-gnu/include/grass/gis.h:636,
                  from GK2.c:21:
 /usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error: field ‘st_atim’
 has incomplete type
      struct timespec st_atim;  /* Time of last access.  */
 /usr/include/x86_64-linux-gnu/bits/stat.h:92:21: error: field ‘st_mtim’
 has incomplete type
      struct timespec st_mtim;  /* Time of last modification.  */
 /usr/include/x86_64-linux-gnu/bits/stat.h:93:21: error: field ‘st_ctim’
 has incomplete type
      struct timespec st_ctim;  /* Time of last status change.  */
 In file included from /home/alba/source_code/grass70_release/dist.x86_64
 -unknown-linux-gnu/include/grass/defs/gis.h:64:0,
                  from GK2.c:21:
 /usr/include/x86_64-linux-gnu/sys/stat.h:365:31: error: array type has
 incomplete element type
          const struct timespec __times[2],
 /usr/include/x86_64-linux-gnu/sys/stat.h:372:54: error: array type has
  extern int futimens (int __fd, const struct timespec __times[2]) __THROW;
 make: *** [OBJ.x86_64-unknown-linux-gnu/GK2.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2017#comment:21>
