[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
trac at osgeo.org
Wed Jun 25 14:32:31 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Parser | Version: svn-releasebranch64
Keywords: base name, prefix, basename | Platform: All
Cpu: All |
Comment(by glynn):
Replying to [comment:12 wenzeslaus]:
> > Yes, I know... But we can always change what is considered legal and
what is not...
Sort of. We can't change which characters exist in various encodings, nor
can we change which characters are legal (at the OS level) in a filename.
> I would not risk anything what is non-ASCII. Moreover, it might be a
good idea to avoid also all characters which has some meaning or must be
escaped/quoted in various command lines or SQL. These include
Realistically, "characters which has some meaning" is anything except
alphanumerics and underscore. Everything else meaning to something or
another. Actually, even an underscore isn't 100% safe.
Even a dash (minus, ASCII 45 = 0x2d) creates issues for r.mapcalc: foo-bar
is parsed as the subtraction of bar from foo; if you want to use a map
named foo-bar (which is valid as per G_legal_filename), the name has to be
quoted in the r.mapcalc expression).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:15>
