[GRASS-dev] [GRASS GIS] #2351: g.version segfaults when the build is not perfect
trac at osgeo.org
Sun Jun 29 03:25:25 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: unspecified
Keywords: GIS_H_VERSION, GIS_H_DATA, libgis, g.version | Platform: Linux
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 wenzeslaus]:
> > The fact that etc/prompt.py indicates that the grass70 start script is
> > outdated with respect to the SVN version. So, the "make install" has
not been
> > properly performed or the "grass70" script in the path is an old
version
> > (e.g old copy rather a link when using a non-installed compiled
version from
> > the source tree). Check that start script first.
> I'm not sure if I fully understand what you are saying. Anyway, in this
GRASS was [http://lists.osgeo.org/pipermail/grass-
user/2014-June/070480.html installed from packages] and the error message
says that there is no `promp.py` file.
lib/init/grass.py used to write "PROMPT_COMMAND=<gisbase>/etc/prompt.py"
into the local .bashrc file which it generates. r60216 removed the
prompt.py script and instead defines a bash function to generate the
prompt.
The error message suggests that only part of r60216 is in effect;
specifically, prompt.py has been removed but PROMPT_COMMAND still refers
to it. This could be caused by the local .bashrc not being generated at
startup and an old version left over from a previous session being used
instead.
> This indeed seems like a broken build or installation, however
`g.version` was failing even in the other case
The prompt.py error may well be unrelated to the problems with g.version.
However, it suggests problems with the build or installation, and
g.version is sensitive to the build and installation.
The problem appears to arise from a combination of two issues: g.version
not being robust against bad input data, and g.version getting bad input
data. The prompt.py issue hints at a possible reason for the latter.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2351#comment:3>
