[GRASS-dev] [GRASS GIS] #2351: g.version segfaults when the build is not perfect
trac at osgeo.org
Wed Jun 25 17:54:49 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: unspecified
Keywords: GIS_H_VERSION, GIS_H_DATA, libgis, g.version | Platform: Linux
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:1 neteler]:
> Replying to [ticket:2351 wenzeslaus]:
> > G7:g.version often fails, segfaults in particular, with some wrong
builds.
> > > g.gisenv set=DEBUG=5
> > bash: /usr/lib/grass70/etc/prompt.py: File o directory non esistente
> The fact that etc/prompt.py indicates that the grass70 start script is
> outdated with respect to the SVN version. So, the "make install" has not
been
> properly performed or the "grass70" script in the path is an old version
> (e.g old copy rather a link when using a non-installed compiled version
from
> the source tree). Check that start script first.
I'm not sure if I fully understand what you are saying. Anyway, in this
GRASS was [http://lists.osgeo.org/pipermail/grass-
user/2014-June/070480.html installed from packages] and the error message
says that there is no `promp.py` file. This indeed seems like a broken
build or installation, however `g.version` was failing even in the other
case where this error was not reported and the point is to make
`g.version` resistant to errors and strange configurations since it is
often used within environments like this (for example it wouldn't be a
good idea to write `g.version` in Python).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2351#comment:2>
