[GRASS-dev] [GRASS GIS] #2351: g.version segfaults when the build is not perfect
GRASS GIS trac at osgeo.org
Wed Jun 25 15:40:36 PDT 2014
 Reporter:  wenzeslaus                                    |       Owner:  grass-dev@…
     Type:  defect                                        |      Status:  new
 Priority:  normal                                        |   Milestone:  7.0.0
Component:  Compiling                                     |     Version:  unspecified
 Keywords:  GIS_H_VERSION, GIS_H_DATA, libgis, g.version  |    Platform:  Linux
      Cpu:  Unspecified                                   |
Comment(by neteler):
 Replying to [ticket:2351 wenzeslaus]:
 > G7:g.version often fails, segfaults in particular, with some wrong
 builds.
 > > g.gisenv set=DEBUG=5
 > bash: /usr/lib/grass70/etc/prompt.py: File o directory non esistente
 The fact that etc/prompt.py indicates that the grass70 start script is
 outdated with respect to the SVN version. So, the "make install" has not
 been
 properly performed or the "grass70" script in the path is an old version
 (e.g old copy rather a link when using a non-installed compiled version
 from
 the source tree). Check that start script first.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2351#comment:1>
