[GRASS-dev] [GRASS GIS] #2351: g.version segfaults when the build is not perfect
trac at osgeo.org
Wed Jun 25 14:29:46 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: unspecified
Keywords: GIS_H_VERSION, GIS_H_DATA, libgis, g.version | Platform: Linux
Cpu: Unspecified |
G7:g.version often fails, segfaults in particular, with some wrong builds.
It seems that it is happening for one or more Ubuntu packages.
Here are some outputs I collected from the users.
> g.version -rge
version=7.0.svn
date=2013
revision=
build_date=2013-12-11
Segmentation fault (core dumped)
> g.gisenv set=DEBUG=5
bash: /usr/lib/grass70/etc/prompt.py: File o directory non esistente
> g.version -rge
D2/5: G_file_name(): path =
/media/massarelli/sdb/Mappe/GRASS/Puglia_Landsat_nord/PERMANENT
version=7.0.0svn
date=2014
revision=
build_date=2014-06-24
build_platform=x86_64-pc-linux-gnu
Errore di segmentazione (core dump creato)
It seems that the strings `GIS_H_VERSION` and `GIS_H_DATE` are broken. I
think that g.version should handle this since it is often used in cases
when something is somehow broken.
== Solution ==
I don't know how to reproduce it but I created a patch assuming that
`G_tokenize` works well with any input and `strstr` is failing with NULL
pointer. The new version wants the results from `G_tokenize` to be of
length 2. If this is not fulfilled, it prints a message or empty values
(with `-g`) and with `g.gisenv set=DEBUG=5`, it prints also the original
strings. Perhaps the message can be replaced by waring which would be
printed even with `-g`.
Patch attached. Let me know if I should commit this. Since I cannot test
this much I'm not sure if it really helps.
== Alternative solution ==
I don't know why `GIS_H_VERSION` and `GIS_H_DATE` are wrong in the first
place but if the problem is really there, maybe they should be obtained in
some less fragile way than as SVN $$ things. Anyway, parsing the variables
is hard and even GRASS is not doing it right (there are spaces at the end
of the output), so some simplification in format of variables might be
helpful.
== strstr function and NULL ==
#!c
#include <stdio.h>
#include <string.h>
int main ()
char * a = NULL;
a = "\0"; // comment to get segfault
printf("a=\"%s\"\n", a); fflush(stdout);
char* b = strstr(a, "X");
printf("b=\"%s\"\n", b); fflush(stdout);
printf("Done\n"); fflush(stdout);
return 0;
gcc teststrstr.c -o teststrstr && ./teststrstr
With `a = "\0";`:
a=""
b="(null)"
Done
Without `a = "\0";`:
a="(null)"
== See also ==
* [http://lists.osgeo.org/pipermail/grass-user/2014-January/069703.html
GRASS-user g.extension]
* [http://lists.osgeo.org/pipermail/grass-user/2014-June/070478.html
GRASS-user keyError: 'version' g.extension grass7 ubuntu 14.04]
* r58437 wxGUI: workaround for gui toolboxes compilation (g.version -r
crashes and menu is not generated)
* and some older emails on mailing lists
Ticket URL: <http://trac.osgeo.org/grass/ticket/2351>
