[GRASS-dev] sphinx documentation for lib python
Vaclav Petras
wenzeslaus at gmail.com
Thu Jun 26 08:21:44 PDT 2014
Hi Luca,
On Thu, Jun 26, 2014 at 11:02 AM, Luca Delucchi <lucadeluge at gmail.com>
wrote:
> Hi devs,
> I'm going to start to work on sphinx documentation for lib/python in
> the next week/s.
> I would like to know which directory do you like to have on the docs.
> I think that all the directories (ctypes, imaging, pydispatch,
> pygrass, script, temporal) should be in.
> I'm not sure about how it works with ctypes but all the other should be
there for sure, although pydispatch and imaging are little bit special
since they partially contain 3rd party code.
what do you think?
> PS
> I would like also to modify pygrass documentation removing all method,
> classes and function documentation (moving it to the new programming
> documentation) and leaving it only the user documentation with
> example. is it ok for you?
> I'm not exactly sure what do you mean by that. I know that there are
different possibilities how to approach this. Can please you provide more
examples and describe it more (e.g. draft the rules how doc should be
written)?
Thank you,
Vaclav
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140626/e2149e8c/attachment.html>
