[GRASS-dev] new wxgui tool: Temporal plot
Anna Petrášová
kratochanna at gmail.com
Fri Jun 27 06:46:12 PDT 2014
On Fri, Jun 27, 2014 at 3:03 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 26 June 2014 19:59, Markus Neteler <neteler at osgeo.org> wrote:
> > nice work, Luca (and thanks to Anna for code cleanup).
> Sorry Anna, but I don't understand because you remove all the 3D code,
> I would like to implement it later (sometime I'm careless but not this
> time :-P )
> Thanks for the improvement of coordinates field.
Sorry for that. I also fixed some other minor things in that commit. Do you
plan to support vector data as well?
What I am not sure about is the usage of pygrass here. The problem is if we
would like to integrate it more in GUI. Currently when you click on the
g.gui.tplot in menu, a standard generated dialog opens and when you fill
the params and press ok, the actual plotting gui shows up, which is
cumbersome. The menu entry could bring directly the tplot, however then
there is a possibility of crashing entire GUI when something goes wrong
(because of using ctypes in pygrass). So one option is to call some t.*
module but there is no t.rast.what only t.vect.strds.observe which requires
vector map. Another option is to wrap the pygrass code and call it as a
subprocess. I don't have time to look at it more now, but we should be
aware of this.
Anna
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140627/e76c2a3e/attachment.html>
