[GRASS-dev] new wxgui tool: Temporal plot
Anna Petrášová
kratochanna at gmail.com
Fri Jun 27 08:01:33 PDT 2014
On Fri, Jun 27, 2014 at 10:35 AM, Luca Delucchi <lucadeluge at gmail.com>
wrote:
> On 27 June 2014 15:46, Anna Petrášová <kratochanna at gmail.com> wrote:
> > On Fri, Jun 27, 2014 at 3:03 AM, Luca Delucchi <lucadeluge at gmail.com>
> wrote:
> >> On 26 June 2014 19:59, Markus Neteler <neteler at osgeo.org> wrote:
> >> > nice work, Luca (and thanks to Anna for code cleanup).
> >> Sorry Anna, but I don't understand because you remove all the 3D code,
> >> I would like to implement it later (sometime I'm careless but not this
> >> time :-P )
> >> Thanks for the improvement of coordinates field.
> > Sorry for that. I also fixed some other minor things in that commit. Do
> you
> > plan to support vector data as well?
> I would like, first I need a vector temporal dataset to test :-)
> > What I am not sure about is the usage of pygrass here. The problem is if
> we
> > would like to integrate it more in GUI. Currently when you click on the
> > g.gui.tplot in menu, a standard generated dialog opens and when you fill
> the
> > params and press ok, the actual plotting gui shows up, which is
> cumbersome.
> yes I have your same feeling, I should create a function like for
> animation tool?
> (other tools have the same behavior of g.gui.tplot for example
> g.gui.timeline)
> > The menu entry could bring directly the tplot, however then there is a
> > possibility of crashing entire GUI when something goes wrong (because of
> > using ctypes in pygrass). So one option is to call some t.* module but
> there
> > is no t.rast.what only t.vect.strds.observe which requires vector map.
> I could use r.what instead pygrass but I would like to escape to call
> external modules
> > Another option is to wrap the pygrass code and call it as a subprocess. I
> > don't have time to look at it more now, but we should be aware of this.
> Just to know, we don't have the same problem using ctypes in the gui?
> In several modules we are using it....
yes we have, digitizer and nviz, I just want to avoid another one when it
would be relatively simple (comparing to those 2) make it safe. r.what
could be a simple solution, although it would be probably slower than
pygrass (not sure if significantly, maybe not).
> > Anna
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140627/ec0e3286/attachment.html>
