[GRASS-dev] g.mlist not compiling
Anna Petrášová kratochanna at gmail.com
Sat Jun 28 10:50:15 PDT 2014
even after distclean g.mlist compilation fails:
gcc  -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra
-Wunused   -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include
-I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include  -D_LARGEFILE_SOURCE
-D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"
 -I/usr/include/postgresql
-I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
In file included from
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3:0,
                 from
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:4,
                 from main.c:25:
/usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:27:21:
fatal error: ogr_api.h: No such file or directory
compilation terminated.
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140628/4e25ff47/attachment.html>
