[GRASS-dev] g.mlist not compiling
epi
massimodisasha at gmail.com
Sat Jun 28 14:15:07 PDT 2014
Exactly same problem here
- Debian SID 64 bit
- grass_7_trunk
- gdal stable, built from source in custom location (no /usr or /usr/local)
Massimo.
On Jun 28, 2014, at 1:50 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi,
> even after distclean g.mlist compilation fails:
> gcc -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -I/usr/include/postgresql -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
> In file included from /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3:0,
> from /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:4,
> from main.c:25:
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:27:21: fatal error: ogr_api.h: No such file or directory
> compilation terminated.
> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
