[GRASS-dev] g.mlist not compiling
Huidae Cho
grass4u at gmail.com
Sat Jun 28 14:19:38 PDT 2014
Hopefully, r61030 fixes your problem.
On Sat, Jun 28, 2014 at 5:15 PM, epi <massimodisasha at gmail.com> wrote:
> Exactly same problem here
> - Debian SID 64 bit
> - grass_7_trunk
> - gdal stable, built from source in custom location (no /usr or /usr/local)
> Massimo.
> On Jun 28, 2014, at 1:50 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> > Hi,
> > even after distclean g.mlist compilation fails:
> > gcc -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra
> -Wunused -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include
> -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -D_LARGEFILE_SOURCE
> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
> -I/usr/include/postgresql
> -I/usr/local/src/trunk/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/main.o -c main.c
> > In file included from
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3:0,
> > from
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vector.h:4,
> > from main.c:25:
> /usr/local/src/trunk/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:27:21:
> fatal error: ogr_api.h: No such file or directory
> > compilation terminated.
> > make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140628/ddb0b93a/attachment.html>
