[GRASS-dev] [GRASS-SVN] r61027 - grass/trunk/general/g.mlist
Huidae Cho grass4u at gmail.com
Mon Jun 30 06:40:16 PDT 2014
Hmm.. v.out.ascii also uses * for all columns and g.mlist uses * for all
mapsets and DEFAULT_WIND. I don't know why I thought there are "many"
modules that use *.
On Mon, Jun 30, 2014 at 9:36 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Jun 30, 2014 at 9:19 AM, Glynn Clements <glynn at gclements.plus.com>
> wrote:
>> Huidae Cho wrote:
>> > Some modules also use * for a special case and I didn't have an
>> > expansion problem with them either.
>> AFAIK, all the modules which currently use "*" do so because it's part
>> of standard glob or regex syntax.
> I still think that I have seen somewhere usage of * in the meaning of NULL
> values. But by short search I found only:
> r.report
>     null   String representing no data cell value
>            default: *
> This is output, so the command line issues are not present, the user
> confusion is.
> r.mask
>   maskcats   Raster values to use for mask
>               format: 1 2 3 thru 7 *
>              default: *
> Manual does not say what * means. r.mask is using r.reclass, so if my
> understanding is correct * should mean all remaining values but then the
> format example does not make sense (or perhaps it does as a format
> description, but not as an example).
> For most utilities, using the shell's wildcard syntax makes the need
>> for quoting inevitable (e.g. the find(1) manual page explicitly
>> mentions this in relation to the -name, -iname etc options).
>> GRASS "gets away with it" because of the option=value syntax and the
>> fact that "=" is uncommon in filenames.
>> > I think '--option value' is a valid point though. Are we going to
>> > ever change option=value to --option value or planning to do so?
>> I doubt that we'd change it in the sense of abandoning support for the
>> existing syntax, but modifying G_parser() to allow either form
>> probably wouldn't require much work.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140630/ef589e40/attachment.html>
