[GRASS-dev] [GRASS-SVN] r61027 - grass/trunk/general/g.mlist
Vaclav Petras
wenzeslaus at gmail.com
Mon Jun 30 06:36:37 PDT 2014
On Mon, Jun 30, 2014 at 9:19 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Huidae Cho wrote:
> > Some modules also use * for a special case and I didn't have an
> > expansion problem with them either.
> AFAIK, all the modules which currently use "*" do so because it's part
> of standard glob or regex syntax.
I still think that I have seen somewhere usage of * in the meaning of NULL
values. But by short search I found only:
r.report
null String representing no data cell value
default: *
This is output, so the command line issues are not present, the user
confusion is.
r.mask
maskcats Raster values to use for mask
format: 1 2 3 thru 7 *
default: *
Manual does not say what * means. r.mask is using r.reclass, so if my
understanding is correct * should mean all remaining values but then the
format example does not make sense (or perhaps it does as a format
description, but not as an example).
For most utilities, using the shell's wildcard syntax makes the need
> for quoting inevitable (e.g. the find(1) manual page explicitly
> mentions this in relation to the -name, -iname etc options).
> GRASS "gets away with it" because of the option=value syntax and the
> fact that "=" is uncommon in filenames.
> > I think '--option value' is a valid point though. Are we going to
> > ever change option=value to --option value or planning to do so?
> I doubt that we'd change it in the sense of abandoning support for the
> existing syntax, but modifying G_parser() to allow either form
> probably wouldn't require much work.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140630/ca9551fd/attachment-0001.html>
