[GRASS-dev] problem using pygrass
Javier Martínez-López
javi.martinez.lopez at gmail.com
Tue Mar 4 09:26:45 PST 2014
Thank you Pietro! I will try again! However, there seems to be a bug
(at least in version 59147) since I am getting NaN values reading some
maps with RasterNumpy, which are perfectly fine when reading them
using grass70 version 57982... They are FCELL! Did you also notice
that? Cheers, Javier
On Tue, Mar 4, 2014 at 4:25 PM, Pietro <peter.zamb at gmail.com> wrote:
> Hi Javier,
> the RasterNumpy class is different from other Raster classes in
> pygrass, because inherit from the numpy.memmap array.
> On Tue, Mar 4, 2014 at 2:38 PM, Javier Martínez-López
> <javi.martinez.lopez at gmail.com> wrote:
>> out = pygrass.raster.RasterNumpy('eco_pa22')
> In the RasterNumpy class you need to specify the raster type with
> mtype when you instance the object.
> and the open method should be call only after you close the map.
> so a working session in the python interpreter could be:
> In [1]: from grass.pygrass.raster import RasterNumpy
> In [2]: new = RasterNumpy('newraster', mtype='FCELL')
> In [3]: import numpy as np
> In [4]: new[:] = np.random.randn(*new.shape)
> In [5]: new.min()
> Out[5]: RasterNumpy(-5.076531410217285, dtype=float32)
> In [6]: new.max()
> Out[6]: RasterNumpy(4.842053413391113, dtype=float32)
> In [7]: new[:3, :4]
> Out[7]:
> RasterNumpy([[-0.74486554, -1.80636668, -0.62290537, 1.10075259],
> [ 0.65961069, -0.71186149, 1.31982756, 0.70869118],
> [ 2.11516094, -1.15944469, 0.71266735, 0.52502483]], dtype=float32)
> In [8]: new.close()
>> Am I doing something wrong?
> You should not use the open method with the RasterNumpy class when you
> instantiate the object, and be careful that you have to set the name
> of your raster map before to close the map or when you close the map,
> see this example:
> In [9]: new.open() # re-open the closed map
> In [10]: new[:3, :4]
> Out[10]:
> In [11]: norm = (new - new.min())/(new.max() - new.min()) # do something
> In [12]: norm.min()
> Out[12]: RasterNumpy(0.0, dtype=float32)
> In [13]: norm.max()
> Out[13]: RasterNumpy(1.0, dtype=float32)
> In [14]: norm.name # the name is not set
> In [15]: norm.name = 'norm' # set the name
> In [16]: norm.close() # then close
> In [17]: norm.close('norm') # give the name and close the raster,
> only from: r59192 [0]
>> Is there an easy way to get the raster map
>> out as a tiff file instead to avoid this problem?
> Why not using r.out.tiff [1]?
> Thank you for testing.
> Pietro
> [0] http://trac.osgeo.org/grass/changeset/59192
> [1] http://grass.osgeo.org/grass70/manuals/r.out.tiff.html
