[GRASS-dev] Temporal: t.register: problem parsing when time zone present
Sören Gebbert soerengebbert at googlemail.com
Tue Mar 4 22:44:41 PST 2014
Hi Yann,
if you need support for time zones you have to use postgresql as
backend. Unfortunately sqlite does not support time zones. A work
around would be to ignore the time zone and use t.shift to temporally
shift the created STRDS by 5h and 30 min to UTC time after registering
the maps. I should notice this in the help page, i don't know why i
missed that ..???!!!
The next thing is that TGRASS uses time intervals in which the end
time is not part of the time interval, but the start time of a
successor. That means that you do not need to know how many days in a
month are;  Interval of one day: start="2004-05-10" end="2004-05-11"
Best regards
Soeren
2014-03-05 6:36 GMT+01:00 Yann Chemin <ychemin at gmail.com>:
> Hi,
> input line is:
> t.register input=ta maps=ta_2004131 start="2004-05-10 00:00:00 +0530"
> end="2004
> -05-10 23:59:59 +0530"
> temporal says:
>   File "/usr/lib/python2.7/sqlite3/dbapi2.py", line 69, in convert_timestamp
>     hours, minutes, seconds = map(int, timepart_full[0].split(":"))
> ValueError: invalid literal for int() with base 10: '00+05'
> Manual says following format accepted:
> start=string
> Valid start date and time of the first map. Format absolute time:
> "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
> end=string
> Valid end date and time of all map. Format absolute time: "yyyy-mm-dd
> yann
