[GRASS-dev] Temporal: t.register: problem parsing when time zone present
Yann Chemin ychemin at gmail.com
Wed Mar 5 00:29:19 PST 2014
Thank you Soeren,
If I want to register an irregular set of daily maps (missing days), will
the end date need to be the next day (say 5 days after this image, 2 days
after in the next image)?
Cheers,
Yann
On 5 March 2014 12:14, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi Yann,
> if you need support for time zones you have to use postgresql as
> backend. Unfortunately sqlite does not support time zones. A work
> around would be to ignore the time zone and use t.shift to temporally
> shift the created STRDS by 5h and 30 min to UTC time after registering
> the maps. I should notice this in the help page, i don't know why i
> missed that ..???!!!
> The next thing is that TGRASS uses time intervals in which the end
> time is not part of the time interval, but the start time of a
> successor. That means that you do not need to know how many days in a
> month are;  Interval of one day: start="2004-05-10" end="2004-05-11"
> Best regards
> Soeren
> 2014-03-05 6:36 GMT+01:00 Yann Chemin <ychemin at gmail.com>:
> > Hi,
> > input line is:
> > t.register input=ta maps=ta_2004131 start="2004-05-10 00:00:00 +0530"
> > end="2004
> > -05-10 23:59:59 +0530"
> > temporal says:
> >   File "/usr/lib/python2.7/sqlite3/dbapi2.py", line 69, in
> convert_timestamp
> >     hours, minutes, seconds = map(int, timepart_full[0].split(":"))
> > ValueError: invalid literal for int() with base 10: '00+05'
> > Manual says following format accepted:
> > start=string
> > Valid start date and time of the first map. Format absolute time:
> > "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
> > end=string
> > Valid end date and time of all map. Format absolute time: "yyyy-mm-dd
> > yann
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140305/2c34410d/attachment.html>
